Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1977 Chevrolet K10 - Starting Problems, Weak Idle and Power Loss
  #173 (permalink)
Old 07-05-2011, 12:46 PM
lt1silverhawk's Avatar
lt1silverhawk lt1silverhawk is offline
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
Hey Pugsy,
Ok, I will try that tonight and report back. Should that not work on the first, try, should I do the same thing again? I ask because the article I've been using for reference states that every time the distributor is moved 180 degrees, the rotor seats approximately 30 degrees clockwise. Yesterday, the rotor was set to face approximately 6:30 position, which is marked as cylinder one on the cap in the final video.
Thanks!
