Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1977 Chevrolet K10 - Starting Problems, Weak Idle and Power Loss
  #174 (permalink)
Old 07-05-2011, 12:14 PM
123pugsy's Avatar
123pugsy 123pugsy is online now
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
When you drop it back in, make sure the rotor points exactly 180 degrees from where you started.
More than likely, you're off 180.
It should only drop in at the 180 degree as the key in the oil pump shaft is a slot.
