Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1977 Chevrolet K10 - Starting Problems, Weak Idle and Power Loss
  #176 (permalink)
Old 07-05-2011, 06:41 PM
123pugsy's Avatar
123pugsy 123pugsy is offline
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
If the oil pump is not lined up, the distrbutor will not drop in so you must have got that.
Are you saying since trying to start the truck you have not turned the distributor different directions to see what happens?
Keep the bolt only snug enough so you can turn the cap by hand in either direction thru the starting process.
