Originally Posted by 123pugsy
If the oil pump is not lined up, the distrbutor will not drop in so you must have got that.
It drops in, but I never made the attempt to straighten up the slot on the oil pump using a long screw driver.
Are you saying since trying to start the truck you have not turned the distributor different directions to see what happens?
No I've been moving the distributor back forth, which is why I made several videos of the starting attempts and merged 'em into a few.
Keep the bolt only snug enough so you can turn the cap by hand in either direction thru the starting process.
At some points, I didn't even have the bolt on. But I'll keep it bolted down just enough.
So now, when I turn rotate the distributor 180 degrees, do I leave the spark plug wires as is or do I redo them as well?
