1977 Chevy 400 small block - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2012, 06:41 PM
only drive chevy77's Avatar
I have a stock 400 sb I want to make it a good runnin motor for street i want to make it have the most Hp but run off pump gas. Like all the stroker kits have 11 to 1 compression but I don't think it will run of pump gas I want it to be fuel injected.. Please help..Like What style pistons, Heads, Crank, cam, intake manifold, headers, oil pump, fuel pump, oil pan, but I want to have a lot of tourque. Please help and find answers.
-Thanks
Old 04-16-2012, 08:13 PM
read this.
http://www.chevyhiperformance.com/te...d/viewall.html
Old 04-16-2012, 08:14 PM
DoubleVision's Avatar
How much money you got?
Old 04-16-2012, 08:19 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Good point DV. What do you have as far as parts now for the build just the block ?
Cole
________________________
They went that a way pilgrim.
Old 04-16-2012, 08:24 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Use the search function here for a ton of builds. Also, use free online calculators to get where you want to be with compression, you can plug in different chamber volumes, bore sizes, gasket thicknesses, quench, etc.
Here's some for starters. Piston volume is the dome or dish in cc's, for instance, flattops with valve reliefs might typically be 7 cc, a dome would be entered as minus, i.e. -10cc, in most calculators. Cylinder head volume is the volume of the combustion chamber in cc. Deck clearance is how far in the hold the piston is at TDC, typically .025" or zero deck, depending on whether the block has been shaved (decked) or the piston compression height (how far up the piston the pin is).
Moving this to the Basic Forum, you'll get more information there and less flaming than posting basic questions here. Welcome to the board.
Semper Fi
Old 04-16-2012, 10:45 PM
I have $10,000
Old 04-16-2012, 10:48 PM
All I have for parts it a bone stock 400 sb with stock carb heads piston crank . It's a running motor I took it out a month ago to pump it up.
Old 04-17-2012, 12:51 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Originally Posted by only drive chevy77
I have $10,000
Are you planning on building this motor yourself? Have you ever built a motor? It would be a shame to sink thousands of dollars into parts and not know what you're doing when putting it together. Anyone can put bearings in, install a crank, install pistons and connect them together with the rods and tighten bolts but do you know how to do it correctly?
Old 04-17-2012, 05:18 AM
you would be better off buying a complete engine and trans from a late model low mile chevy. Like a 6 liter LS with trans. can get a complete setup from fan to tail housing with efi and computer for less than 2000.00.
Old 04-17-2012, 07:45 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
basically what F-bird said, 18cc D dished pistons, look at Keith Black for these. you can likely reuse the stock crank just have it resurfaced .010/.010". i would get pistons with a shorter compression height, ones that would accept the 5.7" rods. buy a set of 5.7" rods. if you want iron heads then go with the DART iron eagle platinum 200cc/64cc heads, if you want alm then go with the AFR 195 heads. a hyd roller cam with around 230°ish degrees of duration at .050 and .550" lift...
and since you want fuel injection here is a kit
http://www.summitracing.com/parts/HLY-550-821/
Old 04-17-2012, 11:33 AM
Yes I have built a motor I have built a few... But I wanna us this motor.
Old 04-17-2012, 12:04 PM
327NUT's Avatar
From this 15 yr. olds "383 stroker" thread........"my poppa gave me a few of his motors and his money" I'll call bull$&*# on the entire deal.
Old 04-17-2012, 03:54 PM
get the f@$& outta here!
Old 04-17-2012, 04:19 PM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
lol this is gonna get good. What is the emoticon for eating popcorn?
Yeah nice language for a 15 year old. Grow up and learn to have some respect.
Old 04-17-2012, 04:24 PM
eloc431962's Avatar
Wiki Edits: 37
I have $10,000
It's good that you do have the funds to do the build, and the good thing is you won't need it all for the build. which is alway's a good thing. IMHO do the search on the site and check out some of the builds on here there are some pretty good ones.
Cole
400 Chevy Small Block 69ChevyC10 Engine 5 05-11-2008 04:50 AM
400 small block chevy shevyman Engine 11 01-15-2007 05:52 AM
Small Block Chevy 400 JohnyR17 Engine 7 10-06-2006 10:46 AM
Chevy Small Block 400 jerry1 Introduce Yourself 2 09-07-2006 08:57 PM
400 small block chevy bo 1972 Engine 1 12-24-2002 07:03 AM
