Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1977 Chevy K20: Engine Suffers from Hesitation/Power Loss When In Drive
  #16 (permalink)
Old 02-07-2012, 04:23 PM
lt1silverhawk's Avatar
lt1silverhawk lt1silverhawk is offline
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
This sounds like an odd question, at least to myself, but I have been wondering if a bad or failing ignition component such as the distributor, ICM, or the coil can act up or show symptoms of failure during certain temperature conditions.
I have been running the truck without a thermostat while doing the cooling system flush. I don't drive it and it rarely gets over 160 degrees. Should be completing the suggested 3-6 hour "flush run"this weekend. I will be replacing all hoses and putting in a new thermostat at that time.
