Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1977 Chevy K20: Engine Suffers from Hesitation/Power Loss When In Drive
  #22 (permalink)
Old 02-10-2012, 08:42 PM
Augusto's Avatar
Augusto Augusto is offline
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
you test the pump for pressure and volume
for pressure you need a tee and a gauge with a piece of hose, you connect the tee between the pump and carb and read the gauge around 5 psi will be ok
now for volume, be careful and don't set your ride in fire, shut off the engine, disconect the line from the carb, attach a piece of hose to it's end and run it to a container of at least one gallon, have someone start the engine and run it at idle, and at the same time start a stopwatch and count one minute, shut off the engine, measure how much fuel was pumped in the container, there should be more than one quart.
