Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1977 Chevy K20: Engine Suffers from Hesitation/Power Loss When In Drive
  #58 (permalink)
Old 02-25-2012, 10:51 AM
Augusto's Avatar
Augusto Augusto is offline
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
Originally Posted by cobalt327
The idle tubes need to be removed. There are spaces below each one that can easily become plugged and cleaning w/o removing them is next to impossible. Because these orifices also contribute to the overall air/fuel ratio/fuel delivery, if they're not right drivability will suffer.
Once the idle tubes are removed, the passages for the idle restrictions and the idle tubes (they're next to each other in the main body casting) can be properly cleaned out.
If the idle tubes were removed carefully, they'll go back in using the original collars just fine. Otherwise, Ruggles sells replacements, both pressed (like stock) or threaded.
I tried once to remove them but they were pretty much stuck in there and I feared damagin 'em, what would be a good way of doing it? heating up the casting maybe? what would be a good tool to grab them without crushing?
thanks for the tip, I'm sure this will cure some of my "junked" q-jets
