Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1977 Chevy K20: Engine Suffers from Hesitation/Power Loss When In Drive
  #98 (permalink)
Old 03-08-2012, 06:09 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Outer ring movement.
Just put a sharpie line across the outer damper ring to the inner hub and use that as a visual reference to see if the damper outer ring is moving over time.
If you put the sharpie line near to the damper TDC line you will be able to see it w/the timing light with the engine running.
