Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1977 Chevy K20: Engine Suffers from Hesitation/Power Loss When In Drive
  #107 (permalink)
Old 06-25-2012, 04:30 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
123pugsy, you're spot on w/the 36 degrees at 3000 rpm. You want the total (w/o the vacuum advance) all in as early as the engine/vehicle combo will allow. This is usually around 3000 rpm (or less if it'll let you) w/o pinging when under a load.
If more info on the HEI is wanted, you can take a look here, especially the section on ignition advance.
