Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1977 Chevy K20: Engine Suffers from Hesitation/Power Loss When In Drive
  #125 (permalink)
Old 06-27-2012, 07:57 AM
lt1silverhawk's Avatar
lt1silverhawk lt1silverhawk is offline
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
I inspected the vacuum line at the intake as well as the modulator. It was dry at the intake, but covered in oil externally at the modulator (along with surrounding parts). And although I've tightened it it up before at the modulator, the small rubber hose was a bit loose again. I removed the small rubber hose connecting the modulator to the metal line and found no ATF inside.
Name:	Transmission Vacuum Hose and Modulator.jpg
