Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1977 Chevy K20: Engine Suffers from Hesitation/Power Loss When In Drive
  #141 (permalink)
Old 07-07-2012, 07:37 PM
lt1silverhawk's Avatar
lt1silverhawk lt1silverhawk is offline
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
Based on the measurements I am seeing, the only valve stem seal that matches is this one at $1.39 each: CHEVROLET 5.7L/350 Chevy small block Gen I Valve Stem Seals - V8 Engine Type - Positive stop Valve Stem Seal Type - No Machine Work Required - 0.684 in. Valve Stem Seal Outside Diameter (in) - SummitRacing.com.
Will one of the sets I purchased earlier be fine, or should I order these instead?
