Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1977 Chevy K20: Engine Suffers from Hesitation/Power Loss When In Drive
  #143 (permalink)
Old 07-08-2012, 01:56 AM
lt1silverhawk's Avatar
lt1silverhawk lt1silverhawk is offline
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
Thank you Cobalt.
I do have the Felpro intake set you listed, but different a exhaust set from one suggested by Summit. The LT1/Vortec seals do strongly resemble the ones I removed, but I think have a wider inner diameter. The valve stems I measured were about 0.341". I will try to get some precise measurements tomorrow. I don't want to install anything that doesn't fit and end up with a set of seals that can't be returned.
As to the pros and cons of using umbrella seals, I did find two threads on other forums which may be useful for others readers:
- let's talk valve seals - The 1947 - Present Chevrolet & GMC Truck Message Board Network
- http://www.stevesnovasite.com/forums...d.php?t=144488
