Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1977 Chevy K20: Engine Suffers from Hesitation/Power Loss When In Drive
  #153 (permalink)
Old 07-16-2012, 05:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by lt1silverhawk View Post
LOL! I tried the pinch/squeeze method but that was a bit difficult with the metal bands around these viton seals. Then again, I'm always so paranoid about damaging anything, I probably didn't apply enough pressure. The tooth pick I would've never though of, since I'm having to use an installation sleeve to protect the seals.
I gotta say, these seals are really tight and it does take some serious pressure to slide 'em down. But once they are, I can tell there aren't going anywhere. I almost became concerned that the exhaust valves may not get enough lubrication.
Thanks cobalt!
I hear ya on the exhausts. If you're keeping the seals anyway I suppose you could hedge your bet and use the "loose" seals on the exhausts and the tight ones on the intakes...
