I am thinking you will have the small O-rings that seal the retainer to the valve stem. This set up uses a tin oil shield under the retainer. I found a page here that shows the same spring compressor I have used successfully on stock SBC springs a number of times. It's inexpensive as well. The seals, retainers, locks, oil shields and O-rings shown there are what you will have- I think. If you have 'positive' seals that are pressed onto the OD of the guide boss, they do come in several different ID and OD. But see what you have (small O-ring or positive type) and we can go from there. |
Tranny fluid in the vacuum hose means its getting sucked by the engine past the modulator. The modulator would require replacement.
I inspected the vacuum line at the intake as well as the modulator. It was dry at the intake, but covered in oil externally at the modulator (along with surrounding parts). And although I've tightened it it up before at the modulator, the small rubber hose was a bit loose again. I removed the small rubber hose connecting the modulator to the metal line and found no ATF inside.
You got to get those oil leaks under control.
The oil is making your vacuum hose gooey. |
![]() Quote:
I will take another look at the spark plugs' electrodes next to see if there is any discoloration. I will also replace every vacuum hose as well as the PCV valve and grommet. I'll try to get to the valve stem seals this weekend. |
I wouldn't remove the hard vacuum line to the modulator. Instead, cap one end and draw a vacuum on the other end. If the vacuum holds- and the line is clear- (no kinks or obstructions, check for this by blowing through it or pull a vacuum unplugged, it shouldn't hold), it's OK.
Some modulator lines went to a fitting on the intake that had a small orifice that acted as a sort of delay valve. If you still are using one like this, be sure the orifice isn't clogged up w/carbon, etc., or the tranny might shift weird. |
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
lt1silverhawk (06-28-2012) | ||
Here are some close up shots of the spark plugs. The were wiped down after removal. I might have the order backwards (put away in a hurry), but they are the correct side. |
Those plug's condition look pretty bad, all in all. The photos are clear enough, but it's the electrode and ground strap and the porcelain that has the info; it helps to be able to see down inside the end of the plug- but in this case it's really not necessary.
I'd say considering how well the compression test went, that it may be the guides passing oil. Is there one side of the plugs that is fouled more or has heavier deposits? The one plug that looks most normal is the top right (circled). ![]() ![]() Driver (L) 1-3; (R) 5-7 ![]() ![]() Passenger (L) 2-4; (R) 6-8 |
Or will replacing the seals take care of this?Quote:
I want to get an opinion: I am thinking of cleaning these plugs off thoroughly and using them one last time just to see where the oil/deposits end up. Or do they look just too far gone? |
![]() It's obvious that the deposits are coming from whatever valve the encrusted side is facing. If the plug is marked for position, you will know if it was the exhaust or intake, although it's almost a moot point; at this juncture the only mechanical fix short of rebuilding the heads is to replace the valve stem seals to see if it helps. I don't remember if you've used Seafoam or not but using Seafoam isn't just "pour it in and you're done". It can cause some crap to be on the plugs if the engine isn't "blown out" by some hard driving. There's a run down of how to go about it here, same place I found the plug photo. Quote:
BTW, the gap looked to be wide on a few of them and a couple had the ground strap tilted up (worst one below); you'd want the gap to be around 0.040" w/the ground strap as close to parallel to the bottom of the plug as possible. ![]() It's better to get the right plug gap from the get-go, than trying to bend the ground strap of a platinum plug IMHO. On some plug brands that means ordering up the right part number to get the gap needed. Anywhere from 0.035" to 0.040" will be OK. If all the engine has seen is just idling in the driveway and putt-putting around the neighborhood, the plugs are going to look a lot worst than if you were driving normally, i.e. for an extended time at full operating temps at normal highway speeds. |
). The picture is a great example.Quote:
I actually just realized that I didn't know the proper way to pour Seafoam into a carbureted engine and looked it up. This seems like a good write -up: How to Seafoam your engine the right way. It says to use the brake booster line to the carb. Apparently there is also a Seafoam Spray that can be sprayed directly into a carburetor throat: http://www.seafoamsales.com/how-to-use-sea-foam-spray.html Quote:
Yep, that's pretty much all I've done with it for the most part for the last two years. Once everything is fixed, it will see more driving. I don't drive on the highway much anymore except on occasion, but I'll try to take it one the highway at least once or twice a week. |
Got to do some work on the valve stem seals.
I ordered a Powerbuilt valve spring compressor (presently going for $20 + free shipping on eBay) and a Lisle valve holder. The valve spring compressor is very similar in design to the units offered by Moroso, Summit, Jeg's and Probuilt but at a much cheaper price. I popped off the passenger-side valve cover and found the source of the leak: a small piece of an older valve cover gasket. Can't believe I missed that. No more working at night. Lesson learned. I hooked up the valve holder to the compressor. There were no directions included so I set it to 100 psi. I had a few moments of frustration because the valve spring compressor shaft that bolts onto the rocker stud was too big. The packaging said it was for both 3/8" and 7/16" studs. Turned out the the shaft has different threads on each end and has to switched. That required popping off a c-clip and reassembling it. Once the compressor was correctly set up, I removed the retainer, spring and seal from the #2 cylinder exhaust (?) valve (the very first one on the right). Now, I need help identifying what I've got. Based on what I've seen and read so far, I believe these are the positive stop seals. |
| Tags |
| fuel, ignition, quadrajet, timing, valvetrain |
| Tbi chevy 350 hesitation. | scout2of6 | Engine | 7 | 07-26-2010 06:21 AM |
| Chevy 350 off-idle hesitation | Yardstick | Engine | 4 | 04-03-2007 10:07 AM |
| my 1977 chevy luv | chevyluver1977 | Introduce Yourself | 2 | 08-30-2005 01:24 PM |
| chevy 350 hesitation | levigarrett | Engine | 2 | 02-10-2005 05:50 PM |
| chevy 350 hesitation | BICHN69 | Engine | 2 | 06-25-2004 10:56 PM |
