1977 Cnotch
Hi,
I have a 1977 C10 that has a rear flip kit and drop spindles up front so its pretty low. I measure 6 inches in the back. It's frame isn't notched though! The guy I bought it from says he didn't have a problem and he loaded a polaris ATV in the back during the winter. Could this be? I'm thinkin he had a sound system and didn't hear it. The axle is pretty close to the frame... I have the bed off right now and am about ready to install a bolt on one but first I wanna see what you all think first. I also wanna add that I'm not interested in the debate about weld in or bolt in kits. I as a welder do not approve on welding the frame and have done so once in my life to fix a crack and was unsuccessfull. I'm not into gambling and when you weld a spot there is a "heat affected zone" around the weld that is brittle then the weld itself is super strong. Ends up being hard spots and you want it to give.. Thanks |
Sounds to me like you have already made you mind up.
So what opinions do you really need to hear. If it's should i then i would say yes you can only go so low without a c-notch, And IMHO when you go so low it would be to your advantage to do the c-notch.JMO Cole |
I wanted to know if anyone has they're axles flipped and frames not notched and hasn't hit anything. Also what would happen after hitting the frame a few times? Could it have enough force to tweak it? Maybe only a real problem when you have a load? I wouldn't think that I'll put much in it because I've got a flatbed pickup for that but never know...
I've just read a few forums and a few guys suggested going with a weld in notch kit and really don't agree so I figured if I address it ahead of time maybe there wont be any wasted posts telling me to weld my frame. |
I have a " C " notch :)
Welded, fabricated and not a problem. My frame is BOXED from the front crossmember to the rear crossmember. WELDED ... I believe a welded " C " notch is actually stronger than a bolt it kit. Go here to see construction photos ... http://www.hotrodders.com/forum/jour...ge=5&reverse=1 |
sounds like youve got your mind made up man
Better put some kind of notch in there
I have a 3-4 on my 79 LWB Always hitting the frame bumpers, but, I tow with it as well. With a car on my trailer---the rear is about 1/2" from the bumpers. These would be the stock bumpers---so there is still quite a bit of cusion before getting to the frame |
| All times are GMT -6. The time now is 02:30 AM. |
