1977 f250 brakebooster problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2010, 06:40 PM
oldfordtrucker's Avatar
I just replaced the master cylinder and the brake booster, bleed the system out. But when i hook up the vacuum line and drive off the pedal sticks down i can pull it back with my foot but as drive further it like the brakes engage by themselves. And as soon as you let off the gas you stop dead, but if i disconnect the vacuum line & block it off the pedal is a little hard but breaks work fine. Can someone please help? The parts store i bought it from says it the right one for my truck.
Old 01-30-2010, 06:59 PM
Ford Junkie's Avatar
No substitute for cubic inches
My guess would be there is an internal problem in that booster. I'd take it off and return it. if brakes release ok with vacum removed from booster.
Just my .02
Tony
Old 01-30-2010, 08:31 PM
fast68's Avatar
likes chevy trucks & boobies
sounds like it has no return spring inside it wow..
maybe its defective, forgot the spring when assembling it.,
or some other problem with it.
normally they just leak vacuum or just dont work at all.
odd..
Old 01-30-2010, 09:34 PM
yeah thats what i sad, thnx for the advice
1978 F250 4x4 390 Engine swap HELP vericero Engine 3 04-16-2009 12:04 PM
1977 Corvette Toddclary Suspension - Brakes - Steering 1 10-10-2008 05:43 PM
1977 Camaro campy Introduce Yourself 2 01-10-2008 01:52 AM
1977 Pontiac Lemans Master Cylinder Question lew racer Suspension - Brakes - Steering 0 04-17-2007 04:33 AM
timing problems smallblocked_S-10 Engine 7 07-17-2002 06:27 PM
