1977 Lincoln Versailles - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2013, 08:45 PM
I am looking at buying a low mileage 1977 Lincoln Versailles with a 351W engine. I was thinking of leving it stock appearing but mod the suspension for better handling and tweeking the engine or swaping in a 90s 5.0.
Do you guys know if I can swap suspension parts from a Mustang to the Versailles. I am thinking of a 2" drop in ride height and overall stiffening the suspension to make it a handler.
Any suggestions on the engine to get 300hp.
Thanks
Jorge
Old 01-08-2013, 03:51 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
300 hp out of a 351 should be real easy and just a mild hop up.
Old 01-08-2013, 04:31 PM
vinniekq2's Avatar
stroke the 351 to 427 if budget allows. a 360 hp 356 is not difficult
1977 lincoln versailles rear brake line diagram Studedean Suspension - Brakes - Steering 1 06-07-2011 11:52 AM
Lincoln Versailles rear disc brakes doc bob Suspension - Brakes - Steering 4 10-22-2007 12:53 PM
1977 Lincoln Versailles rharule Transmission - Rearend 9 08-12-2007 12:09 PM
Lincoln Versailles Ignition System Holder350 Engine 3 08-06-2007 07:47 PM
Lincoln Versailles drasticbean Transmission - Rearend 2 11-22-2004 12:10 AM
