1978 403 olds engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2009, 05:17 PM
I have a 1978 trans am with a 403 olds mobile engine, its all rebuild but it keeps heating up after 30 minutes of running , it has a new radiator, new hoses, new water pump , and electric fan.
thanks for any help with this issue
Old 06-20-2009, 07:36 PM
fast68's Avatar
likes chevy trucks & boobies
shroud? you will need a closed shroud to guide all the air through the fan and radiator
is the fan big enough to sufficiently suck alot of air through the radiator ?
make sure..
thermostat ? what temp is it ? hopefully 195
is one hose hot and the other cold ?
have pressure in the hoses? can squeeze them?
or not?
is the radiator hot all over ? both tanks hot?
what temperature it getting up to max ?
need info
Old 06-20-2009, 08:32 PM
403 olds
I have a shroud as you can see in the picture, the fan is 16 inch in diameter, the thermostat i believe it is 195, both hoses are hot, yes there is pressure in the hoses once they are hot you can not squeeze , yes the radiator is hot all over. the electric fan kicks on at about 120 and it stays on there after, the temperature increases up to 210 and then the engine shuts off.
Old 06-20-2009, 08:38 PM
403 olds
make sure..
or not?
need info
I have a shroud as you can see in the picture, the fan is 16 inch in diameter, the thermostat i believe it is 195, both hoses are hot, yes there is pressure in the hoses once they are hot you can not squeeze, yes the radiator is hot all over. the electric fan kicks on at about 120 and it stays on there after, the temperature increases up to 210 and then the engine shut off.
ID:	38870   Click image for larger version
Old 06-20-2009, 09:02 PM
ericnova72's Avatar
More for Less Racer
As usual, these electric fans are not up to the task of cooling a V8 except in short duration drag usage. Put the mechanical fan and its shroud back on and you will see how much more air the mechanical fan moves. As usual 90% of the time, it is "monkey see-monkey do" misapplication of an electric fan that gets people in trouble. That fan will barely pull enough air for a 4-cylinder.
Old 06-20-2009, 09:07 PM
403 olds
thanks i will consider putting back the mechanical fan
Old 06-20-2009, 09:16 PM
Its funny how some of these websites auto parts like summit racing sale the same set up i have aluminum radiator with the same electric fan for this type of engine. are they wrong for selling this set up?
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
1978 F250 4x4 390 Engine swap HELP vericero Engine 3 04-16-2009 01:04 PM
403 olds T/A advice TommyV_11 Engine 24 04-07-2009 05:58 PM
how far can u bore a 403 olds engine 403pontiac Engine 9 03-23-2009 08:45 AM
olds 403? Meka Engine 15 09-11-2005 02:48 PM
