1978 camaro sub frame mod - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2010, 09:54 PM
im going to be modding a camaro sub frame to a 67 ford truck. is there any of u on here that has done this? any tips/tricks for fitimet would be awsome!!!
i am replacing all of the suspension and brakes on the subeframe also. thanks
Old 09-15-2010, 02:18 AM
just make sure you attach it correctly or you will go through a world of pain trying to get the ride heights level. give yourself alot of meat to mount it to, do you plan on bolting it on like how it comes on the camero? or doing a tube frame underneath and welding it?
and to save yourself alot of pain take the time and find a set of ride height buckets for the top of the springs so you can adjust it easly
Tubbing rear with original frame rails? chieftain Suspension - Brakes - Steering 1 04-25-2007 09:02 PM
1978 z28 camaro rod69 Engine 5 09-29-2006 07:51 AM
LS1 T56 crossmember for 1978 Camaro HELP! badazz81z28 Transmission - Rearend 3 01-28-2006 01:42 PM
1978 Camaro Z-28 Engine Identification HELP daveh Engine 2 10-15-2005 08:46 PM
Nova and camaro sub frame same? Pro1972nova Suspension - Brakes - Steering 2 01-28-2003 10:24 AM
