1978 Camaro Tilt Steering column - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2008, 05:24 PM
CamaroHunter78's Avatar
JD Custom Muscle Car Concepts
I have a 1978 Camaro with standard Steering column and was wandering if I could put a 1980 Z28 tilt column in it and would fit?
Old 02-08-2008, 05:32 PM
life is a temporary assignment
Seem's like it should work.
Old 02-08-2008, 08:00 PM
thanks I think I'll try and if it works I tell y'all
Old 02-09-2008, 10:37 PM
Always look up in a custom
Do some measuring on your columns to see if the lengths are close. You can always cut down if it's too long, or add an extension. The biggest hinderance would be the electrical collar, and making sure they are a matchup.
Old 02-14-2008, 12:25 PM
78 steering
yes it will work, just but a 81 tilt in a 78 z
Old 02-14-2008, 03:19 PM
Thanks Troy that helps out a lot
69 camaro steering column color... camaro freak Suspension - Brakes - Steering 8 02-03-2008 06:46 PM
Steering column for my '29 Mike Britton Suspension - Brakes - Steering 3 12-31-2006 01:09 AM
Ididit Shorty Steering Column Question seadog Suspension - Brakes - Steering 2 05-10-2006 04:47 AM
1990 Full Size Blazer Steering Column problems..tilt boneyard Buick Suspension - Brakes - Steering 5 02-08-2006 11:39 PM
Steering Column Harness on a G-body 1982 SS Electrical 2 07-29-2005 02:06 PM
