1978 caprice - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2011, 09:12 AM
1978 caprice
hi my name is keith from birmingham,al
im tryn to restore a 1978 chevy caprice with the orignal 305 engine
my problem is how to put the belts back on it has three belts
Old 10-22-2011, 09:45 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Welcome to the site.
They should go on a/c then p/s then alternator.IIRC
Cole
Old 10-22-2011, 07:18 PM
The A/C belt is first and it goes around the crankshaft pullery, A/C, and at least one other pulley (PS?).
Then there are two choices for the PS belt. There is a short one that only goes around the PS pulley and the crankshaft pulley. This is usually used with non A/C cars. There is also a longer PS belt that goes around the PS, water pump and crankshaft pulley. I like to use the longer belt because it helps keep the water pump turning if the alternator belt breaks
The alternator belt goes around the alternator, water pump and crankshaft.
Bruce
will 91-96 caprice suspension parts and rearends fit in my 85 caprice? ironindian77 Hotrodding Basics 20 11-15-2012 09:29 PM
96 caprice 8.5 swap to 86 caprice 7.5? brians407sbc Transmission - Rearend 6 08-13-2010 02:30 AM
4.11 on my 1978 LWR100 Transmission - Rearend 1 03-31-2003 02:02 PM
What can be done with a 1978 231 v6? bnesbitt45 Engine 1 01-29-2003 02:16 PM
