1978 Corvette L82 oil question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2008, 12:36 PM
Crazy-J's Avatar
Hi,
Can anyone tell me what oil a 1978 Corvette L82 calls for? I have this engine in my 1969 Camaro but I have no idea what oil to put it in it.
Thanks!
Old 03-14-2008, 02:07 PM
10/40 or 10/30 should be fine.
Old 03-14-2008, 02:18 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Yup. Factory called for 10-30 in most climates. 5-30 wouldn't be required until something like alaskan winters, and 10-40 would be good for an older engine where the bearing tolerances might be a little loose.
Old 03-15-2008, 03:16 AM
Crazy-J's Avatar
Awesome, thanks guys. I appreciate it.
Old 03-15-2008, 04:00 PM
King of my Man-cave.
[QUOTE=F-BIRD'88.................
PTFE resins (Teflon) is not a effective replacement. Why would some one want Teflon in there oil filter?[/QUOTE]
LOL! Even DuPont (makers of TeflonŽ) don't recommend it as an oil or oil additive component.
Seems that it plugs up oil rings, too........
tom
Old 03-15-2008, 05:30 PM
Jmark's Avatar
and here we go again! Another oil thread in the makings! LOL
Old 03-17-2008, 10:14 PM
There are still some oils made with the SL service rating, which means there's still ~1000ppm of ZDDP in them. This may be enough for an old stock engine with a lazy cam profile, but it might be a bit light for anything more modern.
The ones I've seen were 30w or 10w40, and were mostly house brands, not major brands. Same source oils that were either 10w30 or 5w30 seemed to all have the low-ZDDP SM rating.
I'd use some kind of SL oil, and I suspect a can of some kind of high-ZDDP racing oil or EOS added to the mix might be an idea worth looking into, especially if you're running anything that's non-factory.
Chevy 6.5 Diesel has no oil pressure again!!! dorksrock Engine 12 09-02-2012 08:51 PM
Bearing question, oil test shows high lead. Jmark Engine 2 06-24-2006 04:29 PM
Blower gear oil question Arrowhead Engine 4 03-29-2006 09:15 PM
Oil Filler Question horvath Engine 2 03-17-2003 01:52 AM
