1978 El Camino Manual 4spd gearing - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2006, 11:34 PM
I've got a nice low miles 78 Elke with a 350-Edelbrock manifold/New Quadrajet,headers manual 4 speed stock from factory. I'm getting a howl from the rear end when I unload (back off throttle). If I slip it to neutral it quiets a bit, No noise on acceleration. I think I may have damaged it in a street race when I chirped into 2nd at 7 grand. That's when it started.
We'll I was thinking I might want to understand what the car came with and what I might want to put in it. Any ideas.
polid
Old 01-27-2006, 03:32 AM
Might be a Saginaw. If all three shift levers are mounted to the side cover, it's a Sag. They came with one of four possible gear ratios, identifiable by the number of annular rings (if any) on the input shaft. For ID info & parts, go to: http://www.dandltransmission.com/saginaw.html
Old 01-27-2006, 09:59 AM
Thanking u
Yep it's a Sag.
Any idea on rear end noises?
Want El Camino 60's-70's project. sixties Hotrodding Basics 2 01-11-2006 07:34 PM
1978 El Camino SS Weimer Hotrodders' Lounge 8 02-09-2005 04:46 AM
El Camino Song matt37015 Hotrodders' Lounge 4 01-14-2003 04:18 PM
el camino rear end ?? mac95 Transmission - Rearend 3 01-01-2003 01:26 PM
1978 El Camino steering/brake swap craigw Suspension - Brakes - Steering 1 09-02-2002 12:25 PM
