1978 ford Ltd 9" w/ posi.?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2002, 09:00 PM
fatherandson53's Avatar
Father of Many
Post 1978 ford Ltd 9" w/ posi.??
I have a 1953 chevy 3600 3/4 ton with the original rear and I have the chance to buy a 1978 ford ltd. rear with posi. , disk, and 9" rear. Will this work in my truck??? Please help.Is $125 a good deal? What should you expect to pay?
Thanks-Mario and Tyler <img src="confused.gif" border="0">
Old 11-12-2002, 09:42 PM
BOBCRMAN@aol.com's Avatar
Post
the width is wrong and the spring perches are on the wrong side of the axle shock mounts are wrong. but i'm sure there are a lot of people who will take it off your hands!! with some fabrication you can make it work, the price is excellanttttttt.
[ November 12, 2002: Message edited by: BOBCRMAN@aol.com ]</p>
Old 11-13-2002, 08:45 AM
Father of Many
Post
Is it too wide ?? I can have someone shorten it if so and as far as the springs in the wrong place could'nt I just use my leafs off of my original rear and just weld on the brackets??? Help please.
Thanks-Mario
Old 11-13-2002, 12:24 PM
Maverick's Avatar
Post
A GM 10 bolt from a Nova fits perfect! The spring perches are space correctly and will fit your orginal springs. And the gear ratio is great for cruzing and hwy. You wont have to do anything to it but clean it up and paint it. If you want Posi. check out <a href="http://www.powertrax.com" target="_blank">www.powertrax.com</a> Ill be adding this to mine. I got mine out of '76 Nova for 100 bucks.
Old 11-14-2002, 12:29 AM
Father of Many
Post
Thanks for the help and ideas.
-Mario
Old 11-14-2002, 12:12 PM
Wiki Edits: 49
Post
With the help of a good machine shop you can have the existing mounts removed and just weld on new ones in the proper location. However, you will need to have the rear end narrowed and axles re-splined. For a good 9” with disks it would be worth the effort and expense.
Good luck.
Centerline
{url}http://www.hotrodsandhemis.com[/url]
[ November 14, 2002: Message edited by: Centerline ]</p>
Old 03-09-2003, 10:00 AM
Post
fyi 1978 and 79 lincoln cont.comes with ford nine with disc brakes i picked one up at the local salvage for 50 bucks
Old 03-14-2003, 05:19 AM
390xw's Avatar
Post
hi all just wondering what the going price is for a 9" or mini spool i am just curious cus they r hard to get here and if they r as cheap as youse r talking i reckon i could sell a 100 of them no prob thanks for any info
Old 03-14-2003, 06:12 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
Jump on it. Even if you dont need it, you can make money on it. Paint it up real purdy and you it will bring $250. If you do get it and dont need it, please PM me. I am in need of one of the emergency brake levers if you would be interested in selling it. I would make it worth your while. I travel for a living and have looked through alot of wrecking yards with no luck finding the lever.
I have yet to find even one of those rears in a yard. All the lincolns I find have the rear removed, so if you think you will use it in the future I'd buy it.
Chris
