1978 GMC van specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2013, 02:21 PM
1978 GMC van specs
Am doing a tune-up in a 1978 GMC Vandura 25, need spark plug gap and ignition timing, thanks
Old 03-03-2013, 02:46 PM
68NovaSS's Avatar
Wiki Edits: 9
Give up more information, what motor, A/C? Trans, 2 bbl, 4 bbl or?
Assume the sticker under the hood is gone?
Old 03-03-2013, 02:49 PM
Sorry, my bad. 305/auto, 4bbl
Old 03-03-2013, 02:51 PM
No sticker under hood or on valve covers. have a manual but it's in my pickup 300 miles away.
Old 03-03-2013, 05:21 PM
68NovaSS's Avatar
Wiki Edits: 9
Chiltons calls for R45TS plugs gapped at .045, timing for both auto and manual trans 4* BTDC, vac disconnected and plugged, for the '78 Van 305, and 6* for a '79 305. Idle is 600 rpm for a manual trans, 500 auto.
Old 03-03-2013, 06:47 PM
Thanks for the info, greatly appreciated
Old 03-03-2013, 06:56 PM
poncho62's Avatar
Wiki Edits: 5
Yep.....Chevy HEI ignition....045
Older with points.....035
Ontario Rodders
Install 700r4 into 1978 1 ton chevy van ? cowbowlb Transmission - Rearend 2 11-07-2012 09:50 PM
Replacecment fuse block for 1978 GMC heavy truck dwb812 Electrical 1 09-05-2012 04:16 AM
All Wheel Drive GMC Van BigDawgsEatFirst Transmission - Rearend 6 09-28-2005 04:14 PM
A few pics of my '54 GMC 1-Ton Panel Van DesertPanel Hotrodders' Lounge 10 10-10-2003 01:38 PM
no brake lights or flashers on my 1980 gmc van gm3bud8 Electrical 2 01-06-2003 01:33 PM
