1978 Mercury Marquis Rearend? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2005, 09:07 PM
Does anybody know what kind of rearend came in the late 70's full size mercs? and what would cause a clunking sound from both brake drums when rocking the car side to side? everything rolls smooth without any noise or grinding. except the clunk.
Old 11-07-2005, 01:25 AM
aka Duke of URL
Most likely a 7.5" RG. The axles are held by C-Clips at the pinion gears. If the axle bearings are good (these are pressed into the axle tube ends) and no sign of axle seal leakage (worn axle shafts at bearing surface), you may have to shim the C-Clips with stock to eliminate the excess in/out movement of the axle shafts. This procedure is described in the appropriate year shop manual.
Old 11-07-2005, 07:30 AM
Thanks you, that helps alot, ive only messed with ford 8 and 9 inch so far.. so this c clip thing is new to me.
Rearend clunk briz Transmission - Rearend 8 09-11-2005 07:14 PM
87 Mercury Grand Marquis dgpopwell Engine 4 08-30-2005 10:33 PM
strength of 8.2 inch 10 bolt rearend??? 70chevelle327 Transmission - Rearend 4 02-11-2004 10:07 PM
rearend for a Model A 30coupe Transmission - Rearend 10 11-25-2002 08:04 PM
