1979 351 cleveland Ford Ranchero... No power ..killing batteries
Son drove to school just fine. After school battery was dead..We thought? Tried to jump it and nothing..not even a click.... Tried to bypass solenoid...nothing.... Lights come on but wipers will barely move even with charger on the battery. I found a big gauge wire coming from the back of motor that has no insulation and is un hooked on one end...
Help me please..... Thanks in advance |
Since you are jumping the solenoid, your components are your batter, solenoid, cables and starter. All indications point to a bad battery or loose connection on your battery cables. Rich |
cars body. Without that connection, you're turning your cooling system into part of the electrical system, this is bad... |
Link
Doc here,
Sounds like that bare wire may have melted off your fuse link...Check that wire and see where it goes (Like Ign. Switch) and check the fuse link to see if one of the three wires is missing... To quick test the ground, just get your jumper cables, and hook the black to the battery ground and the other end to a good spot on the block and try it again....If it cranks you got grounding issues... Doc
Aftermarket Solutions Electronic & Electrical Innovations Last edited by docvette; 08-31-2005 at 05:34 PM. Reason: Added info |
Thanks again for your help. Got sidetracked with my 1970 Chevy C/10. Dang timing keeps moving about every 2 months. I get a sonic boom and need a new muffler each time. I reset the dist. and all is okay until it does it again. Might need to replace the timing chain I'm sure. Those booms are scary.
| will a 351 fit in ranchero? | aaronv8 | Engine | 5 | 01-31-2004 10:39 AM |
| 351 clevland 1974 ranchero | 5ohchevy | Engine | 5 | 10-09-2003 04:09 PM |
| Hotrodders Knowledge Cluster: Power Steering Conversions | Jon | Suspension - Brakes - Steering | 0 | 09-03-2003 11:20 PM |
| Should I use a high amp alternator or 2 batteries | ss crazy | Electrical | 29 | 05-27-2003 01:32 PM |
| Geo Metro Power unit in a 61 Ranchero | mortecai | Suspension - Brakes - Steering | 1 | 03-28-2002 08:06 PM |
