1979 C30 454
Hello guys,
I have a 1979 C30 with the 454. The truck is going to be used as a DD + work truck, pulling brush and logs. I've been looking into the summit racing cheapo headers, and then 3" back to undecided muffler. I'm new to v8's so i have no clue what H or X pipes do, or how they help performance/sound. Also was thinking about changing the carb, and get rid of the q-jet. But ive also read, that if they're tuned right, then they are great carbs. Since im new to carb motors as well, i have no clue about how to tell if it is adjusted right, or even how to adjust it. Last thing, and last thing that will be done is a cam. I've read that a 205/210 lift cam will work great for this motor. Any suggestions on cams? Also read that Comp Cams XE262h is a great cam aswell. After these upgrades should i worry about the added power hurting the th400? Reason I ask is, I blew the tranny in my last car. |
Exhaust:
I was planning on doing headers to straight pip to mufflers and then turndowns right before the rear axle. But 2.5" sounds good, i was just thinking 3", since thats the size of the collectors on the summit racing headers. Will it matter much which size exhaust i go with, since I'll be doing the cam? Cam & Heads: I'm guessing the 396-427 heads would be cheaper than vortec heads. So do you know what the casting number is on these. And will i need new valves, rockers, push-rods etc if i go with these heads? Also, could I use a smaller head gasket to raise CR? or would this be bad idea? If I could do it, and not blow head gaskets left and right, how much do you think it would raise CR? If I'm not wrong, stock CR is 7.7:1 isn't it? On the cam, the Comp Cams XE262h, is going to be way to big, or just a little to big? I really don't know much about specs on cams. RPM Range: 1,300 - 5,600 Valve Lash: Hydraulic on both Valve Timing: .006 Duration: Intake-262 Exhaust- 270 Lobe-Center Angle: 110 Duration @ .050" Lift: Intake-218 Exhaust-224 Intake Centerline: 106 Valve Lift: Intake-0.504 Exhaust-0.51 Lobe Lift: Intake-0.298 Exhaust-0.301 Torque Converter: Im just wondering what a higher stall would help, with towing? Is something to with power loss? Or is it a strength thing? Intake: I haven't looked around, but the edelbrock 7164 looks promising. After all of this, how much hp and tq do you think id be looking at? Thanks for the help so far, I really appreciate it. I'm trying to get as much info on what I'm wanting to do with the motor, now, so I know what I need to save for, and research. |
For the exhaust, use jegs or summit headers, 2.5" pipe back to thrush turbo mufflers. It will sound great on a big block and free up a ton of power. Changing the cam in a low compression engine isn't going to do much for power. You'd be better off putting and intake and carb to go with the free flowing exhaust. A good ignition system always helps power and efficiency so that would be something to think about doing. If you will be driving the truck on the street a lot, the high stall converter will hurt gas mileage big time and you may fing the constant high rpms to be annoying over time.
When you say ignition, just a better distributor, plugs & wires? Also, im not sure, but the motor is HEI right? What is HEI and should i look for parts with this in mind? Has anybody used/tried the e3 Diamond fire plugs? I ran them on my 4 cyl, and at the track shaved .1ish off the ET. And seen on powerblock, that they gained like 8hp-12hp on a bigger v8 motor(cant remember which motor). |
The hei is a big distributor with a coil on top. Tuning up the ignition system is a good idea. Pick up some ac delco plugs, a new coil, cap and rotor, and a good set of wires. I haven't heard of diamond fire plugs, i use ac delco and have not had any problems.
O, I see. Well thanks guys for all the information. I've got a pretty big list of parts, but hopefully, if I get enough work, ill have everything before fall.
The diamond fires, are suppose to be better because of the fuel and air is ignited because of the prong that's on them. If you go to they're website, they have an animation of what they do. I'm not sure if they work as advertised, but like I said, they did a dyne run with different sets of spark plugs. And the e3's made better power, and somehow got better mpg too. Once again, thanks guys. you've been very, very helpful. |
http://www.e3sparkplugs.com/mediacenter.php its the first and second video. |
Redman, with all due respect to you, if you did not buy the truck new and if you have not disassembled the motor and measured all the parts, then you have no idea what you have for a motor. Previous owners could have swapped in anything from a 396 to a 402 to a 427 to a tall deck 366 or 427. They all look pretty much the same from the outside. You need to find out what you have before you begin collecting parts for it. Here are two images I copied from google to show the difference in the standard deck (9.800" block deck height) BBC block and the tall deck (10.200" block deck height) BBC block. You can see that on the tall deck block, there is more material between the centerline of the top water pump bolt hole and the top of the block deck....
All I'm saying is, determine first whether you have a standard deck or tall deck block. Then let's go from there. |
Check out the pricee on the 65,000v polished alum. HEI distributor and 10.5 mm pro comp spiral wires at www.kmjperformance.com I got both for around 70 bucks and it realy lit up my engine. they fit both sb and bb chevys.
true, true. Could I not get the numbers off the block? instead of going all out and tearing it down and messuring. |
http://www.chevy-camaro.com/chevy-ca...gine-codes.asp |
Hopefully tmw. Plus hopefully ill get the insurance card too, so i can get tags and start pulling the trailer with it. |
| 1979 silverado 454 shortbed | unitedbuyers | Introduce Yourself | 3 | 11-05-2009 03:33 PM |
| replacing a 454 with a 350...... | Treozen | Engine | 8 | 03-05-2008 01:28 PM |
| 454 into 427 | Alan Byers | Engine | 22 | 01-18-2008 12:36 PM |
| 1979 454 horspower | pottymouth_1 | Engine | 8 | 05-07-2007 09:57 PM |
| 454 or 427 for 70 Chevelle? | f100beatertruck | Engine | 3 | 11-25-2003 05:29 PM |
