1979 Camaro, need converter rear gear suggestions - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2011, 11:36 AM
mikey1476's Avatar
hello i have 79 camaro and i'm getting ready to drop motor in finally,but got a couple of questions,first what i got....
357 sbc,
crane blue racer cam,488/510 lift,234-244@0.50 lift duration,112 lobe sep.
pro-comp aluminum heads..(bought bare).
190 runner,64cc,2.02/1.6 valves.
1.5 roller rockers
performer rpm air gap intake
performer 750 carb
stock bottom end
turbo 350.
i need advice on torque convertor(what size) and rear gears.the camaro will be used just to cruise around in,maybe race it once or twice just for fun.any suggestions would greatly help.thanks in advance mike.
Old 06-09-2011, 12:33 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Moving to transmission/rear forum for better exposure.
Semper Fi
Old 06-12-2011, 09:52 PM
reply
10 inch converter 2800/3200 stall.3.73 gears
what the relation between torque converter and cams and rear gear Pupsvette76 Engine 6 01-09-2010 04:42 PM
97 Camaro rear gear change? 75sprintguy Transmission - Rearend 4 11-05-2008 12:52 PM
1979, dodge 360 timing gear? supercab78 Engine 2 11-01-2005 08:43 AM
Converter or Rear Gear change???? voodoosurfer Transmission - Rearend 3 03-24-2005 10:43 AM
Converter stall and rear end gear pircjo Transmission - Rearend 3 10-07-2002 04:45 PM
