1979 Camaro printed circuit board - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2013, 10:15 AM
Last journal entry: MY WIFE'S NEW REFIGERATOR
My Camaro has the infamous circuit board problem known for these cars. Is it possible to do away with the board and wire each guage seperately without problems other than wiring the lights to work? I've thought about installing new aftermarket guages; but, my wallet says no. I'd appreciate a reply from anyone who's tried this.
Thanks
Old 06-21-2013, 01:50 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
My initial thoughts were, what kind of problems are you having? Have you gone through all of the normal checks to resolve those problems? How did you determine that the PC board is the problem?
Take a problem for example, gas gauge not working. The sender often is the problem is this case.
Printed circuit boards are repairable unless the substrate is destroyed.. How are your soldering skills?
vicrod
Old 06-21-2013, 02:18 PM
None of the guages other than the speedometer and voltage are working. The bulbs in the cluster are new; but, not working. Both working guages operate separately from the circuit board. The metal strips where the plug connects to the circuit board have come loose from the adhesive that hold them in place. The problem I suspect is that I'm not getting good contact from the plug to the board. Granted, it would be easier to put a new circuit board in; but, I want to cure this problem for good.
Old 06-21-2013, 09:30 PM
I found a fix for my car. The contact points on the circuit board are loose and when you push the plug into it they cross each other or don't make contact at all. I read a thread dealing with this. You use super glue to hold the contact points to the plastic. This will keep everything in line when you plug the socket in the board.
printed circuit board redsag 78 Electrical 4 12-11-2012 12:14 PM
70 SS non gauge printed circuit board 70 SS Electrical 3 01-25-2011 11:53 AM
circuit board trouble american muscle rulz Electrical 2 06-24-2007 11:17 AM
circuit board installation masman Electrical 7 03-30-2006 11:07 PM
1976 Corvette Tach Circuit Board schematic silvernblack Electrical 0 09-25-2003 08:01 PM
