1979 chevy front end swap. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2007, 04:19 PM
I have a 79' chevy but want to have the front end off of a 85' or so, when they went to the quad headlights. i was woundering if it is an easy swap? will it just bolt in or will i have to modify anything?
Old 03-01-2007, 05:05 PM
poncho62's Avatar
Wiki Edits: 5
I take you are talking about trucks..............It will probably bolt on, but I think the belt line changed in 80.
Ontario Rodders
Old 03-01-2007, 05:07 PM
By the way I am talking about ether a truck or a k5 blazer
Old 03-02-2007, 05:42 PM
TailGater's Avatar
Blood, Sweat, and Gears!
you can swap it, you will need pretty much everything in front of the windshield, hood, fenders inner and outer, rad support, bumper, i believe the wipers are different as well, and you should get the wiring harness of of the '85 as well as the headlight wiring will be different.
Hope this helps,
Chris
54 chevy with mustang2 front end 8283hockey Suspension - Brakes - Steering 2 07-31-2006 08:37 PM
Chevy rear end swap Truplayainfla Introduce Yourself 1 10-23-2004 11:07 PM
front end swap blake Suspension - Brakes - Steering 3 10-09-2004 11:56 AM
front end help on 85 chevy truck digitalfrek Suspension - Brakes - Steering 1 10-02-2004 08:04 PM
1960 Chevy truck front disc brake swap importeater Suspension - Brakes - Steering 1 07-10-2003 12:16 PM
