Thread Tools Search this Thread share on Facebook
  #1
Old 02-16-2009, 07:56 PM
79f150-460 79f150-460 is offline
1979 f150 460 CID carb and intake help!!!!
I'm needing to know what would be the best combination of a carb and intake for my old truck. i was looking into a Holley street avenger 670 cfm part# 0-80670, a Holley 770 cfm part# 0-80770, and an Edelbrock performer 600 and 750 cfm. all vacuum secondaries, and electric choke. i haven't looked at any intakes yet, but was wondering if anyone could help me with this. It has a Holley carb on it now that i believe is a 650cfm. thanks
Register now (free) or login to remove ads
Old 02-16-2009, 08:41 PM
old fords old fords is offline
72 grabber 51F-1 65 chevystang
assuming the motor is basically stock I would go with the 670 SA. I would go with a performer rpm intake
Old 02-16-2009, 09:22 PM
richard stewart 3rd's Avatar
richard stewart 3rd richard stewart 3rd is offline
Last journal entry: 351W rebuild
Hi,
Here is a good bit of information about the 460, including carb & intake, timing gears & chain (oem are 9*retarded) & other good stuff.
Rich
http://www.hotrodders.com/forum/460...460+carb+intake
http://www.hotrodders.com/forum/70s...460+carb+intake
Old 02-17-2009, 07:54 AM
thanks for the help
Old 02-17-2009, 08:00 AM
the truck is completely stock but i want to modify it without going real extreme with it. maybe just a carb, intake, and some headers and exhaust. i just want power and for it to sound good.
Old 02-17-2009, 08:08 AM
52F1 52F1 is offline
Your plan is great based on extended RPMs
If most of your driving will be UNDER 3500 RPMs and you are looking for fuel mileage then I would use a Stock Iron Intake. It will give better Low speed performance and fuel economy. Now if you Plan on being in the throttle much over 3500 Rpms alot then get the performer RPM or the Weiand Stealth intakes.
With the Stock intake I would go with the 670 Carb
if you are going to RUN up the RPMs then I would get something in the 700 Range
It all depends on the usage
52F1
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1979 f150 460 CID carb and intake help!!!!"
ThreadThread StarterForumRepliesLast Post
Fabricating intake manifold.gemini86Engine2510-02-2009 01:10 PM
My intake and carb?71haulnazzEngine309-16-2008 10:27 AM
SBC 283 intake & Carb Swap Problemsiceman_77Engine402-13-2007 05:49 PM
Intake Manifold and CarbOzz1967Engine912-29-2005 12:34 PM
Stipud ? Maybe/Need help determining my Carb and intakeArchonRacingHotrodding Basics801-15-2005 06:03 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
