1979 F250 Rear Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2007, 05:08 PM
I want to switch my rear drum brakes over to disk brakes. You wouldn't happen to know where I can find a kit for that do you? I have a 1979 F250 Custom RWD with a 400cid. Thoughts?
Old 07-14-2007, 06:11 PM
fast68's Avatar
likes chevy trucks & boobies
you should be able to make a simple caliper plate out of plate steel and use stock front rotors and calipers of some application(re-drill rotor bolt stud holes pattern if needed, weld up and grind smooth old holes first))
should be lots of info and pics out there on this on google and on pirate4x4.com
many have done it, lots and lots
good luck
1979 Buick Lesabre Rear axle?Hubs Drilled? redlightning Transmission - Rearend 7 08-13-2006 12:37 AM
Switching 71 Camaro 10 Bolt Rear End To Disc Brakes TORI1 Suspension - Brakes - Steering 1 04-13-2006 03:38 PM
Front Disc Rear Drum Brakes bigjoedo Suspension - Brakes - Steering 2 07-02-2004 10:16 AM
Ford Explorer Rear Disc Brakes Lloyd Topping Jr Transmission - Rearend 4 11-10-2002 02:06 PM
rear drum brakes oldcarguy85 Suspension - Brakes - Steering 3 01-08-2002 09:41 PM
