1979 Ford Granada Tranny acting really weird - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2009, 02:19 PM
My buddy has a 1979 Ford Granada with a 4.1L 250 and a 3 speed auto. He tells me that sometimes the car will not move forward, so he has to put it in reverse and drive backwards for a few hundred feet. Then he can put it in drive and it will be fine. He said it only does this after it has been idling for a little while. I have no idea whot could be wrong besides the tranny takin a dump... anybody have any ideas??
Old 05-06-2009, 07:01 PM
The mobile view is crap
can he put the car down in first when it is doing this and drive. i have always heard first and reverse are the same band/gear. check out the shift cable that goes from the shifter down to the linkage. or check out the linkage itself. change the filter and fluid in the pan. i don't recommend to anyone have the transmission flushed.
Old 05-06-2009, 09:05 PM
fast68's Avatar
likes chevy trucks & boobies
i vote for shifter/linkage issue as well. hows the tranny fluid look and smell ? bright red ? dirty red ? have any smell to it other than nice trans fluid ?
linkage may be pretty worn out and in need or work/adjustment under the car. may have a pivot bushing worn out or missing especially with how old the car is.
always wondered what cars ford put the 250 L-6 into hmm..
good luck
Old 05-06-2009, 09:28 PM
Wiki Edits: 31
Granada/ Monarch's, Mavericks and '70-'75 Mustangs could get them...
Granada/ Monarchs had the optional 3+1 4spd toploader known commonly as the Granada 4spd
700R4 tranny into a 1940 Ford questions 40forddgc Transmission - Rearend 8 01-21-2009 01:16 PM
Ford 4r55e tranny problems 62galaxiguy Transmission - Rearend 4 02-24-2008 04:25 PM
Engine, tranny, rear end, ford CustomFord Engine 3 01-06-2003 12:25 AM
1979 Ford F-150 4x4 460 Headers TomR10 Engine 5 09-24-2002 11:21 AM
whats the best ford tranny for street rods? shagginwagonvic Transmission - Rearend 24 04-27-2002 10:22 AM
