Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1979 Monte Carlo questions
Old 04-27-2012, 09:38 PM
pricesgarages's Avatar
pricesgarages pricesgarages is offline
if its never going to see a v8 keep the 200 tranny 79 is a non lock up they were weak but if it is rebuilt correctly it will give u good service its 45lbs lighter than a th350 and geared better but u need to to make sure the tv cable is corectly installed if you plan on a v8 swap go with a th350 id be willing to guess u have either a 2.41 or 2.73 rear gear ratio so u would be fine with a 3 spd auto
