1979 silverado half ton with 350 small block - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2006, 10:38 AM
I need to know about how hot should the temp gauge run?
I don't know if it might need a radiator.
Old 10-05-2006, 11:01 AM
Should run around the thermostat temp (180-195) if the sensor is in the intake, if it's in the head expect about 5-10 degrees hotter. And if it ain't got a t-stat its gonna run pretty d#&* HOT.
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders....Sorry but this forum is for..Site Suggestions and Site Help. The question that you posted belongs in the Engine forum. That way the Engine Gurus will see it and give you a answer. My 99 Silverado temp runs from 195 -200. I bought it new and this is what it normally runs. They run the later models at a higher temps than they used to ...to get better gas mileage. Hope that helps ya out.
Old 10-05-2006, 11:03 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
This is the Site Suggestions and Help forum. Discuss issues relating to Hotrodders.com in this forum. Feel free to ask questions, or post comments, suggestions, or constructive criticism.
Specific tech questions should go in one of the tech forums. In your case the engine forum. You will get a lot more exposure there from the members that are well versed in that area. Let them know a lot more information so that they will be ble to give you an informed opinion. What temperature is your truck running at now? Do you have antifreezes in your coolant? Is the coolant level full? Have you had your radiator flushed recently? Is your fan working?
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
350 small block motor dragonman2292 Engine 2 08-11-2006 01:00 PM
big block or small block? jesse01 Engine 5 03-24-2005 06:16 PM
Installing Turbo 350 onto Chevy small block Help ecarpener21 Transmission - Rearend 9 05-13-2003 10:17 PM
Reconditioning a small block 350 chevy v8 Butchardos Engine 1 03-24-2003 10:28 PM
