1979 Trans Am - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2005, 06:42 PM
1979 Trans Am
My 1979 Pontiac Trans Am will not go into reverse. It is a 4 speed manual tranny.
Old 06-02-2005, 07:47 PM
As one of the Moderators here......let me WELCOME YOU here.
Check the linkage.........I have seen them hang up ....
DEUCE
Old 06-03-2005, 12:32 AM
Did it go in before?
Does it refuse to go in at all, or does it grind? If it grinds, your clutch may be in need of adjustment. If it's not completely disengaging when you push the pedal down, the gears will not stop spinning, and it will grind. It might also make it hard to downshift in the forward gears, and can lead to synchronizer damage.
Will the shifter even go to the left side of the gate? I don't know what kind of reverse lockout your shifter has, but my '72 Nova has a detent ball down inside the shifter mechanism that doesn't respond well to smooth pressure. It works better if I slap the stick to the left from the right side of the gate.
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
1979 Trans Am octane Hotrodders' Lounge 17 10-26-2003 06:47 PM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 01:23 PM
maybe this forum can help me wih my 1979 trans am duckhead4life Hotrodders' Lounge 59 01-09-2003 03:31 PM
need hep with this 1979 trans am duckhead4life Engine 3 08-01-2002 07:34 PM
