1979 Trans Am body mounts..help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2010, 08:10 PM
Hey, I have a 1979 Trans Am in good shape. I just changed the body mounts and ran into a problem on the left rear(under driver seat) mount. The bolt is just spinning in the undercarriage. I presume the weld keeping the nut(?) mounted between the floor and the crossbeam has broken. Am I going to have to cut into the floorboard to get this out? Is there another way to fix this problem? The original mount that is stuck is in OK shape..will it be a major issue if I just leave it in? Any info on this will be appreciated!
Thanks,
Jim
Old 05-19-2010, 09:02 PM
yes there is no other way.
chevy 350 to trans am motor mounts BadassBandit Engine 4 03-08-2009 07:27 PM
Body Mounts for 1935 to 1940 Ford car 32chevy vett General Rodding Tech 7 02-19-2009 09:21 AM
65 Belair - replacing body mounts sabino56 Body - Exterior 1 05-02-2006 11:14 PM
1979 Trans Am Gene Decker Suspension - Brakes - Steering 2 06-03-2005 12:32 AM
V8 dakota swap, trans mounts DakotaDon General Rodding Tech 1 08-26-2003 03:22 PM
