Thread Tools Search this Thread share on Facebook
  #1
Old 12-26-2011, 08:03 PM
Trans Am Tony Trans Am Tony is offline
1979 Trans Am shaker scoop question...
Hi. I have a 79 T/A with a 455 Olds in it. When I bought it, previous owner has attached the shaker to the hood. I would like to mount the shaker to the engine (like it was stock), but I know the 455 in it is taller than the 301 it came with, or even the 403 Olds that was an option.
WHat mods would I have to do to get the shaker to work with the 455. Nothin' beats watching the shaker doin' its thing.....
Register now (free) or login to remove ads
Old 12-26-2011, 09:41 PM
Nuck Chorris Nuck Chorris is offline
Is a 455 olds really taller than 403? I thought they were of the same exterior dimensions. Most 79 TA's were 403's, so finding a air cleaner base that will work shouldn't be impossible. Otherwise you could head down to the junk yard, find some olds air cleaner bases, make a plan, then measure, cut, weld. I did the latter with my TA awhile back. I fit a 403 scoop to a SBC, so it can be done.
Old 12-27-2011, 08:01 AM
bad436z28's Avatar
bad436z28 bad436z28 is offline
Last journal entry: 79 z28 436sbc/4speed bright cobalt blue metallic,soon to be.
403 air cleaner
just find you a 403 air breather assembly it will mount on the 455 it has same demensions as 403,shouldnt be hard to find at all.then mount the shaker like they did from the factory.
Old 12-27-2011, 09:20 AM
FmrStrtracer FmrStrtracer is offline
An Olds 455 is taller and wider than a 403, plus, the overall height of the engine will depend on which intake manifold you have.
Old 12-27-2011, 02:42 PM
Whoops! I forgot to say that. The intake is an Edelbrock Performer olds 455 with a 750 Edelbrock carb (elec. choke). Could I still use this intake with a 403 shaker? I really don't want to hack up a nice one to fit it stock appearing.
Old 12-27-2011, 05:06 PM
MJS69's Avatar
MJS69 MJS69 is offline
I'm guessing not....your two choices are to fabricate a shorter assembly, or get an adapter...Butler performance has them, but they are a bit spendy...
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1979 Trans Am shaker scoop question..."
ThreadThread StarterForumRepliesLast Post
74 gto shaker scoopairguy67Body - Exterior611-08-2010 06:31 AM
79 Trans Am Shaker Hood Scoop fit issueGladisBody - Exterior303-07-2007 07:25 PM
Shaker Hood Scoopoldskools10Body - Exterior209-05-2006 12:21 AM
Shaker/Scoopmustangdude947Body - Exterior1606-30-2004 05:02 PM
Shaker Hood ScoopFlame RedBody - Exterior110-27-2003 03:21 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
