Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1979 Volvo 264 2.66 liter V6 idle problem
Old 08-04-2010, 08:28 PM
LATECH's Avatar
LATECH LATECH is offline
Also if the cold start injector keeps spraying it will run rich you would see black smoke ( at least some) out the tailpipe. You could check it by simply unbolting it after you run it for a minute or two and see if it is still spraying.
