Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1979 Volvo 264 2.66 liter V6 idle problem
Old 08-04-2010, 07:40 PM
LATECH's Avatar
LATECH LATECH is offline
You might also want to read up on how to check the 4 different system fuel pressures. Should be 4 it goes like this: rest pressure after system is shut off and wait about 5 minutes it should hold pressure see specs.
cold start pressure at startup running pressure after warmup and deadhead pressure ( max pressure) that the pump is capable of. read the precautions especially on dead head pressure as you dont want to hurt the pump.
I found a digram for the system and number 12 looks like the photo.It is the auxiliary air valve ( cold start up air regulator) anyhow this pdf ( download it so you have it) is at: http://www.bmfi.com.au/files/interjectKjetronic.pdf
Looks like good info.
