Thread Tools Search this Thread share on Facebook
  #1
Old 08-09-2011, 04:09 PM
Stubby686 Stubby686 is offline
1980 C3 blower motor wont shut off
The blower motor lever (up/down) is marked low thru hi and the control lever (right/left) has off all the way to the left. With the blower lever on low and the control lever all the way to the left on the off position the blower motor is still on low. I just picked up this car and the last guy's fix was just to unplug it at the relay in the motor compartment. Would this be a shorted relay and the up/down lever should shut it off or would it be the cable for the control lever (right/left) that can be adjusted under the center console. Or is that adjustment on the cable under the center console for something all together different.
In a nut shell just wondering what shuts off the blower motor ......
Register now (free) or login to remove ads
Old 08-09-2011, 04:43 PM
helrazr3's Avatar
helrazr3 helrazr3 is offline
im on a highway to hell
Last journal entry: grill and headder panel
i believe that it will always run very low with the switch all the way down you need to shut the heat or a/c system off for the blower to stop completely also make sure your not in defrost mode that will keep the blower on also
im sorry for some reason i thought you had a chevy truck.... what kind of car is it?
Old 08-09-2011, 04:57 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
X2.
Cole
Old 08-09-2011, 06:32 PM
Yeah huh , what it is would help. Corvette ...........
Both the heat / defroster and the A/C are in the off position or as far left as they can slide at least. I did notice one of the controls has a white plastic adjuster on the cable about 4 inches off the assembly. I'm assuming that will just adjust the throw of a door or something to direct air flow inside the airbox. Then the other control I believe is vacuum driven. I have pulled the A/C pump off and do not plan on using any of that stuff. When I got the car the wires for the A/C pump were already unplugged along with the plug on the relay to power the blower motor. Who ever "worked" on this car had the theory of just unplugging non vital components that did not work properly instead of fixing them.
At least I know where to look now. I figured the blower motor would be "off" when all the way down like modern cars of today are. I see how the other controls turn it on & off now and that just controls the speed it runs. Makes sense
Old 08-09-2011, 06:43 PM
helrazr3's Avatar
a lot of times the levers will engage a switch mounted on the underdash unit itself you can get a wiring diagram of your car from ebay fairly easy i would start there and then chase your problems 1 at a time
Old 08-10-2011, 05:10 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Wiki Edits: 26
There was a time when they ran the heater motor all the time. I think the theory was it would keep fresh air coming into the cab at all times.
Chet
Old 08-10-2011, 05:41 PM
Thanks guys ..... there is really no problem at all I guess. It's always on low whenever the key is on according to the link crashfarmer posted. I see the reasoning to keep fresh air moving but now I wonder how long blower motors last when they are always on .......
Thanks again
Old 08-10-2011, 06:16 PM
eloc431962's Avatar
Wiki Edits: 37
Thanks again
For years on end.
Cole
Old 08-10-2011, 08:18 PM
pepi's Avatar
pepi pepi is offline
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Does it run in the acc mode, asking because I would think that would be a huge draw on the battery. Thinking about the under the tree polishing and having the radio on keeping you company.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1980 C3 blower motor wont shut off"
ThreadThread StarterForumRepliesLast Post
Engine Wont Shut Off if the Brakes Are On...?playswithfireGeneral Rodding Tech2012-27-2010 10:33 AM
Help to figure out why heater blower motor wont workeric32Electrical509-09-2008 05:41 PM
305 wont shut down..help!!85S-10v8Electrical1203-25-2008 09:47 PM
my heater wont shut off!coderedElectrical205-15-2007 12:08 AM
Engine wont shut off, really wierdataririderEngine1301-27-2004 11:10 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
