Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1980 camaro z28 with a TH350.. swap tranny??
Old 03-11-2009, 05:45 PM
fast68's Avatar
fast68 fast68 is offline
likes chevy trucks & boobies
howdy there,
people should realize/remember that there are three lengths of the th350 in 2wd form
700r4 is the same as a th350 with 9" tail
found in some vans, some full size cars and wagons, and all full size trucks
ppl dont seem to understand this
there is more than one th350
plus there is also a lockup converter variant of the th350, it is call teh TH350-C
i have one in the basement original to a '81 C-10 pickup 350 olds diesel i parted and junked. 10 bolt bellhousing to fit all GM 90 patterns
you need to measure the tailshaft housing length to know what trans model will fit in place of it
but since i see it is a camaro i know it is the 6" tail length and a 700r4 is 3" longer than these, so you need a 2004r in which is 4 speed auto and will fit right in place of the th350 other than crossmember location
however, if you have an old arc welder you couls simply cut off 3" of the driveshaft and use a 700r4
i am doing the same thing because i am swapping from 9" tail th350 in my 78 c-10 pickup over to a 1987 3L80HD trans(th400 body with 27 spline output shaft and it is 3" longer than a 9" th350 trans)
very easy to cut and re-weld a driveshaft
did the same thing for my 2wd s-10 pickup not too long ago, i replaced the original two piece shaft with an 89 full size van single piece shaft, had to cut 1.5" from it to fit the s-10
also it is hassle, not hastle
good luck
