1980 chev 350 timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2013, 02:32 PM
I have purchased a edelbrock power package containing 64cc performer rpm heads, rolling thunder cam (234in, 238ex degrees at .05) timing gears and chain set, air gap intake, also have Howards hydraulic roller lifters and push rods, hooker headers and street fire HEI distributor, edelbrock 650 carb the rest of the engine is stock. I'm getting prepped for the tear down and the only procedure I'm not sure on is how to time the distributor and which key way to use on crank gear. Any procedures or suggestions for this build would be very helpful. Thanks
350, chev, timing
350 Chev timing, compression, vac 33PlyCoupe Engine 9 07-20-2009 10:41 PM
350 sb 1980 blazer mike56557 Engine 2 09-21-2008 08:21 PM
Big chev 454 and small chev 350 bolt pattern boneyard Buick Engine 4 01-18-2006 09:07 PM
timing my 69 chev 350 truck looking for tips kdx250 Engine 2 10-12-2004 07:53 PM
1980 datsun 350 swap. need help icedragon Engine 5 12-16-2002 06:01 AM
