Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1980 Chevy C10(350 battery)
Old 01-04-2011, 02:28 PM
kukamojo kukamojo is offline
You are charging the battery and basically draining it by running the truck. The gradual drop in voltage is your battery going from full charge to crap. You need to check out your charging system. It definitely is not working. Alternator / Voltage regulator are the first 2 things to check.
