1980 Chevy Caprice - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2005, 04:07 AM
1980 Chevy Caprice
HI, Im Dcoy i have a 1980 Chevy Caprice 305 5.0 4b and The car wont start, I just wen to the store and got some gas, when i got home I turned the car off, i forgot to roll the windows up so i turned the key to turn the car back on but i wont start, now just 10 days ago i changed the start because it did the same thing, the battery like stays dim while the car is on and when you press the gas the light goes away, before I cut te car off i heard a little buzz noise that wouldnt go away unless i turned the head lights off, and I really dont know what to do, the head lights are bright and all other lights come on but i cannot start the car or turn the key to roll the (power) windows up. Please help if you can, it will be appreciated
Old 09-21-2005, 04:18 AM
Enigma10's Avatar
NZ Nev
Last journal entry: Assembly
Earth Lead
Check that the earth lead to the motor is still connected and has a good ground.
Old 09-21-2005, 04:46 AM
docvette's Avatar
Wiki Edits: 12
System
Doc here,
First of all, charge the battery up for 8 to 10 hours at about 10 amps..Then take it and have it load tested at the local auto parts store..If it's bad replace it..
Next if the battery is good and CHARGED fully, Does it now start/run? If so, turn everything on, power wise and measure the voltage across the battery running..if less than 13.75 or Ideally 14.4..you have a charging/Regulation problem..
Being as you are getting a low / dim Battery lamp and a buzzing relay (usually the choke relay, but could just be lights on buzzer) Sounds like you have some dead diodes in the alternator..you can Replace the diodes yourself or just replace the whole alternator, ... your choice based on your skill level and tools..
Have the alternator tested when you do the load test..
BTW, these are usually free at the local auto parts superstore..If the alternator tests good (which I doubt..) then you have grounding problems...
Your ground should be set up as such, The battery cable ground to any handy bolt at or near the starter, from there, get a battery cable that has 2 3/8 ring terminals on it ($6 bucks at wally mart or auto parts place) and ground that to the frame..From the engine block ground at the starter, run 2 #10 wires, the first to the firewall, and the second to the alternator ground lug or mount bolt...
USE proper Star washers, Sheet-metal screws / bolts and locks, and burnish ALL the paint and grease from the grounding areas..this will give you a rugged reliable grounding system that will most likely outlast the car...
If the Alternator is powered white Along with the mount, remove both and the hardware, and sand or water blast them back to clean bare metal...then when you reinstall add aluminum wire bonding paste to all hardware and anywhere the mount or alternator touches the block ..
This is electrolysis , the mount is aluminum and he block is steel (what the hell were they thinking?)..that powder is an insulator..
It will ALSO dissolve the water pump impeller like a mild acid..so you might want to think about replacing that while you are in there too..(less stuff to pull down again..)
If all of that dosn't solve the problem..you may have ONE out of 3 fuse links burned off the main lead..(less likely though)
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 05-18-2012, 09:06 AM
Had the same issue with my 1980 caprice about a month ago. I changed the alt, it fixed the problem.
Old 05-18-2012, 09:25 AM
S10 Racer's Avatar
http://www.warsprints.com
This thread is 7 years old, he hopefully has it fixed by now.
Old 05-18-2012, 09:28 AM
Lmao, I didn't notice but none the less it could help someone who's using google to find answers
Disc brake conversion on a 1980 chevy 1/2 ton pickup junkman Suspension - Brakes - Steering 12 02-16-2009 04:33 PM
OOo... I hate chevy people! 87442lover Hotrodders' Lounge 64 01-23-2006 08:10 AM
9" to chevy conversion bigiron Transmission - Rearend 4 10-11-2005 10:32 PM
Chevy sending unit in a Ford Tank AnD Engine 0 05-14-2003 04:34 PM
New Member Introduction - 48 Chevy Rodder 48 Chevy Rodder Hotrodders' Lounge 0 10-20-2001 03:04 AM
