1980 chevy rear end?
I have a 71' C10 chevy truck
355ci 400hp;415ft/lbs torque Tremec 5spd I pulled a 1980 chevy 1/2 ton rear end.Because I liked the gearing.I was wondering if I put it under my 71' if it will hold up?I plan to install a powertrax diff. in it also.If not do you know of any rear ends that will hold up?I have a ford 9" but I wanted to keep the chevy bolt pattern.Thanks Bonzipenguins |
my truck has leaf springs.The saddles need to be moved 2 inches outside to fit.
12-bolts came with 30-spline axles and 10-bolts used to come with 28-spline axles. It doesn't sound like a big difference but a 30-spline is actually about 32% stronger then a 28-spline.
In 88 GM went to 30 spline axles in the 8.5" 10-bolt. When you get your new diff just get a 30-spline one. You can use junkyard axles out of a K5 or Sub from 88-91 or get aftermarket axles. |
Thanks Triaged.I'll definately do that my next trip to a pick-a-part.
Regards, Bonzipenguins |
| pre-65 Chevy rear end info-- anyone knowledgeable? | matt_ramsey | Transmission - Rearend | 6 | 03-29-2005 09:00 AM |
| Chevy rear end swap | Truplayainfla | Introduce Yourself | 1 | 10-23-2004 11:07 PM |
| 1951 Chevy Coupe Rear End Swap | JLF-JLF | Transmission - Rearend | 14 | 04-12-2004 03:49 PM |
| 65 Chevy Rear End Gears | mweber | Engine | 3 | 01-03-2004 04:05 PM |
| 96 Chevy PU Rear end howls | tommytempest | Transmission - Rearend | 3 | 04-29-2003 01:49 PM |
