1980 corvette alarm - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2006, 08:05 PM
1980 corvette alarm
My corvette alarm started going off yesterday all by itself. It is a factory installed unit and came on the car originally. I have tried several ways to get it to rearm but it just keeps sounding off. I can only silence it by disconnecting the battery. Any ideas ?
Old 08-06-2006, 12:12 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
For now..pull the fuses, and disconnect the siren..that'll keep it quiet.
On mine, the module was in the left rear quarter panel hidden vault well..Check there for a removable door..(they have a few spots I can't remember where they all are..) If it's there , check the plug and harness for bad, burned, bent or corroded pins..and / or a damaged module (road fodder..) If good..
ON mine, all the wires junction at the left side center console panel and went under the cluster / dash from there..a good spot to check..and troubleshoot from..your going to need a factory alarm manual for your system also. If you get one...please post it..I need one!
BTW..mine was abandoned long ago..about 2 or 3 aftermarket systems ago..But all the "EXTRA " wire was left..so this time I stripped it all out in favor of the new system, what so far has worked flawlessly for over 4 years...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Installing a Corvette IRS in a 34 Coupe Mc D's 34 Coupe Suspension - Brakes - Steering 12 05-18-2010 12:20 PM
alarm system crownver Electrical 5 05-26-2006 04:21 PM
1980 corvette battery keeps going dead? Aboveknee Electrical 5 01-23-2004 03:56 PM
1980 Rochester Corvette ratt7 Engine 2 10-31-2002 12:20 PM
