We're winning the case!
Hotrodders Bulletin Board > Tech Help > Electrical
  #1
Old 01-18-2004, 06:16 AM
Aboveknee Aboveknee is offline
Smile 1980 corvette battery keeps going dead?
hi, i am having a problem with my 1980 corvette batterys going dead, i charge them up and it will stay charged enough to start the car, but if i let the car sit for 4- or more days the battery will go dead? I have replaced the old battery with a new one and it does the same thing? I am wondering if it is in the brain or modulator for the car? does anyone have any idea what may be causeing this? the car is in exalent shape with only 19550 miles on it. please email me at aboveknee@aol.com if you can help.
Old 01-18-2004, 06:45 AM
poncho62's Avatar
poncho62 poncho62 is online now
poncho62's barnstar
Wiki editor
Wiki Edits: 5
You have a drain somewhere in the circuits of the car. Something is turned on, even when the ignition is turned off.
With the ignition off, pull the positive wire off the battery. Put a 12 volt tester between the post and the cable. If it lights up, you have a drain somewhere. Start pulling fuses, one at a time. When the light goes out, that is the bad circuit.
Also, check the grounding point of the negative cable. It is under the car, on the frame under the battery. These are known to corrode.
Old 01-19-2004, 03:30 PM
tm454 tm454 is offline
Tazz
you can also pull the fuses one at a time and watch for it to spark as its pulled or replaced with the key off to see whats draining the power.
Tazz
Rat Rods Rule!
Old 01-23-2004, 04:54 AM
mikeweyman's Avatar
mikeweyman mikeweyman is offline
I had the same problem with a bronco 2 . the batt would drain overnight. believe it or not the regulator was on the way out, and there was an internal short in the alternator itself wich was draining the battery, go figure, mike
Old 01-23-2004, 03:44 PM
Bryan Munday Bryan Munday is offline
I would suggest you use an amp meter to see what your amperage draw is. Anything over 200mA will cause a std. cranking battery to go dead after a few days to a week of non use. If you connect an amp meter between a battery cable and a battery post, using the meter to complete the circuit, you will see the total draw. Then to identify the circuit that drawing to much, start pulling fuses. If you only get small changes with the fuses, remove the charge wire from the alternator. Remember that clocks, stereo memory's & computers (ECM) will have a small draw normally under 40mA .
Good Luck.
Old 01-23-2004, 03:56 PM
reborn55 reborn55 is offline
might want to get alternator checked. A shorted positive diode will kill a battery.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
